Not rendering images anymore in Edit or Read mode
I’m having a really hard time with getting images to render that are external links. Even public ones.
What I’ve tried:
I’ve deleted all my custom CSS and custom JS to see if I somehow created a bug, and it’s just not working. I also disabled all the Community Ppps that may access or modify html, css, js. (CustomJS, Dataview, Image Captions, Image Upload Toolkit, JS Engine, RunJS)
I’ve tried all these variants:
![Dropbox](https://www.dropbox.com/scl/fi/h50ku2dkjyje2q0qd5905/2025-02-21-01.17.07_Data-Augmenter_MainContainerUI.gif?rlkey=fogfxpdr9m1clomt6hn22d5gn&st=2x3xxpbm&dl=0)
![250](https://www.penguinrandomhouse.com/books/711959/number-go-up-by-zeke-faux/)
<img src="https://www.penguinrandomhouse.com/books/711959/number-go-up-by-zeke-faux/" alt="Here is my alt">
These lines are rendering here the same way they do inside Obsidian. If you see this post it’s just a random little image icon that suggests there should be an image, but there is no image rendered.
Dropbox
250
Here is my alt
Any external image or gif I try to reference does not render in either Edit or Read mode.
Is there a possible reason this is happening? Should I delete and reinstall the Obsidian app? What to do…
Update, happening on my other vaults as well.
For the book links you’re linking to the web page for a book, not an image. The image link for that books is ![250](https://images1.penguinrandomhouse.com/cover/9780593443835). You can get the link to the image by right clicking on the image and selecting “Copy image address”.
It’s likely that the dropbox link is also incorrect.
I figured that book image out. But the dropbox link is correct. Is there some kind of security issue?
Is there a recommended third party image and gif host you recommend for obsidian?
My brief research leads me to believe that Dropbox has disabled the ability to publicly embed images in the past 5-10 years.
I can’t in good faith recommend an alternative as I don’t host images on a third party, I keep them all in Obsidian.
Best of luck!
