Wrong spelling is marked correctly for both languages, suggestions are only made for English.
Operating system:
Windows 11
Debug info (Sandbox Mode):
Obsidian version: v0.15.9
Installer version: v0.15.6
Operating system: Windows 10 Home 10.0.22000
Legacy editor: off
Base theme: light
Exactly the same.
You can easily reproduce with an empty vault in the sandbox.
If it at least would be possible to change the order of the languages, that would help.
German is my primary language, English only used in rare cases, so I need suggestions for German much more often than English.
But each time I add both languages (no matter which one is added first), English is always on top (I guess they are ordered alphabetically). Result is, I only get suggestions for English.
I can use multilingual. Also when you use to multilingual, you should not expect to get the same results as if you were using English alone and German alone.
That’s curious.
I downloaded and installed obsidian, created a new vault (all default, no plugins), activated spellcheck with both languages: same result: suggestions are only shown for English.
Crosschecked with another language (Italian), now only German suggestions are displayed (so I assume always only the first language in the list).
Checked the same with a new user on my computer and a fresh Obsidian installation, same result.
Anything else I can do to narrow down the cause of the problem?
Hmm. I can’t reproduce this either. With German + English UK and/or US, I get relevant suggestions in both languages. Tested in a new vault, also works as expected. (I re-used your example sentences for reference.)
now it’s getting really interesting.
What else could I try?
As mentioned above: even with a clean and fresh installation with a different user-account on my windows 11 machine I can reproduce the behavior.
So, what can be so special about my system??
(it’s well known that I am a very special guy, but my computer?? )
I am seeing the same issues, almost.
If I have two different languages like English (UK), Serbian I loose option to have spellcheck,
If I have two different languages like English (UK) and Swedish (French or German) spellchecker is working
So its the issue with some languages. Maybe Serbian used here is Cyrillic script, and the rest of text is not cyrillic so that is what messes up.
Not sure.
The spellchecker is broken for me. Dual language. Most of the words (but not all so it doesn’t even make sense) are underlined and suggestions are mixed up (English suggestions for French words, French suggestions for English words) like if the spellchecker was confusing the two languages.
