Hi. I was wondering if there is a way to link notes to the calendar plugin. I know that I can link the “daily note”, but I can’t find a way to get other notes, for example, meetings, to link to the daily calendar so I can search for them that way. Would I need to link them to the “Daily Note” in order to do this, or is there some other way?
Thanks, yes, it’s not possible with Liam’s Calendar. Good to know I wasn’t the one that couldn’t find a way around it.
I downloaded Fantasy Calendar, but am not sure how to use it or if it will create conflicts with Liam’s. If you know anything I can read to set it up well, I would appreciate it.
