Hello there,
I need some help with the shabegom/buttons Plugin. In the github-issue-section I already created some threads, but maybe you got an idea or the same problems like me.
Remove multiple Buttons with the Inline Button in different notes
→ I created some buttons and would like to delete all of them after hit one. My buttons like:
name 1045BF
type prepend text
action #1045BF
remove [1045, 1044, 1043, 1042, 1041, 1040, 1039, 1038, 1037]
^button-1045
name 1044BF
type prepend text
action #1044BF
^button-1044
name 1043BF
type prepend text
action #1043BF
^button-1043
If I now write in the same note the Inline Button code button-1045
button-1044
and button-1043
and hit one of them, all works well. There is the created tag and the other buttons are gone.
But if I do the same thing in another note, the button just create the tag and removes itself. The other one will be still there. Any ideas?
A button to change the title of a note
→ Is there any possibility to create a button which changes the title of a note? E.g.: The title is “06 Name - Title” and I would like to have the numbers from above in the title as well. After hitting the Button there should stay “1045, 06 Name - Title”. Is something like this possible?
Thank you for your help!
Knigge
