Need help with batch exporting notes to pdf
I am using obsidian on Ubuntu 24
I want to batch export my notes as a pdf so that NotebookLM can summarise them.
1. I exported my keep notes as a takeout file.
2. I imported the takeout file using Importer plugin. This now displays as Google Keep folder in the left hand side pane.
3. I created a TOC note of this folder which contains links to all my notes within the Google keep folder.
4. I clicked the more drop down menu on the top right hand side of the screen and chose Better Export Pdf.
5. I accepted the default settings and clicked export.
6. The notes started laoading in the display window so Impresumed the export was working
7. I waited for about 30mins for the process to finish.
8. The export file did not open on finishing and I could not find it in the folders below
a) default obsidian vault
b) my documents folder
c) my downloads folder
Can anyone help me either locate the pdf or export my notes correctly.
