Need help to format the title for the daily notes
Greetings,
I’ve enabled the Daily Notes plugin, but I can only set the date format.
I’d like to have something like this: “date Daily Note”, for example a file named 20220324 Daily Note".
I can’t find the option to add a string of text other than the date in the settings.
How can have it?
Is it possible?
Thank you.
I’m using periodic notes, I’m guessing the syntax is the same.
You need to escape the characters like this:
YYYYMMDD \D\a\i\l\y \N\o\t\e
It works.
Thank you very much!
You’re welcome :slight_smile:
