Need better suppor for functions
We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one.
There are cases when the user needs to implement complex logic in the tasks, e.g. the user needs to take the starting data of a task and the ending date and make them into a duration span, check if the deadline is approaching soon, etc. All this requires writing code. However, despite we can use the DataView plugin to do something like:
function print_duration(location) {
	const page = dv.pages(location).first();
    const val1 = new Date(page.Start);
    const val2 = new Date(page.End);
    const val3 = (val2 - val1) / (1000 * 3600 * 24);
    dv.span(`Task B took ${val3}.`);
in a dataviewjs block, we can only use that function inside that block. Thus, whenever we want to use that functionality, the whole block needs to be written.
There should be a way to define a separate file where utility functions, written by the user can be added. Those functions should be importable from any task and reusable. This seems a lot like writing a plugin, but many users do not want to write a whole new plugin, we just need a few extra functions that we will have the freedom to implement for our particular usecase
I do not see any workaround, but living without this functionality.
As this is about the Dataview community plugin, I suggest adding a feature request on their GitHub page.
Hi @ariehen
Thanks for your feedback the issue has been opened here
