Native indent syntax that doesn’t conflict with CommonMark
Native indent syntax that doesn’t conflict with CommonMark: .> proposal
Obsidian’s Tab action and 4-space indent are exactly what many users want
indent and layer grouping in Preview work great. The feature itself is awesome.
The problem: 4 spaces conflict with CommonMark. In the spec, 4 spaces mean
code block. Obsidian interprets them as indent. So notes that rely on
Obsidian’s indent break compatibility the moment they leave Obsidian.
| Context | 4 spaces / Tab mean |
| CommonMark spec | Code block (<pre><code>) |
| Obsidian | Indent, layer grouping |
What Obsidian built is awesome — but unfortunately, while it has widened
Markdown’s reach, it has also diverged from the spec. That creates two issues:
  1. Different mental model — “4 spaces = code block” is fundamental in the
spec. Obsidian users who indent with Tab/4-space learn a different rule.
When they share notes or switch tools, the mismatch surfaces.
  1. Compatibility is broken — The same .md file, viewed in GitHub, VSCode
preview, Obsidian Publish, or any CommonMark renderer, shows indented prose
as code blocks. The note silently changes meaning outside Obsidian.
Obsidian vaults are plain .md files. Notes are shared via GitHub, GitLab,
VSCode preview, Obsidian Publish, and other renderers. Users who rely on
4-space indent get a great experience inside Obsidian, but their notes are
no longer portable. We’re asking users to choose: either use indent (and break
portability), or follow the spec (and lose the indent UX).
Use case: subordination without enumeration — Sometimes a paragraph belongs
under another — contextually subordinate — but it’s not a list item, not a
quote, and doesn’t need its own heading. Headings and lists cover many cases.
They don’t cover flowing prose with visual subordination.
Introduce .> as a native indent syntax — same indent + layer UX, but without
conflicting with CommonMark.
Syntax
.> This starts an indent at depth 1.
No prefix needed — stays inside until a blank line.
..> Depth 2, nested inside depth 1.
...> Depth 3.
Back outside.
Rules
  • Dot count = depth. .> = 1, ..> = 2, ...> = 3, etc.
  • Same model as > (blockquote): lazy continuation, blank line to close.
  • Renders as <div class="md-indent md-indent-N"> — easy to style with CSS.
  • On parsers that don’t support it: shows as plain text. No breakage.
Rendered preview
| Source | Rendered |
| Normal text. | Normal text. |
| .> Indented once. | Indented once. |
| Continuation line. | Indented continuation. |
| ..> Depth 2. | Indented twice. |
| Back outside. | Back outside. |
Why this fits Obsidian
  1. Same UX, no conflict — Indent + layer grouping, but with syntax that
CommonMark doesn’t reserve. No need to override “4 spaces = code block.”
  1. Portable — Notes work in GitHub, VSCode, Publish, any renderer that
adds support. No silent breakage.
  1. Spec-aligned — No divergence from the spec. Users keep a single mental
model across tools.
  1. Readable source.>, ..>, ...> show depth in raw text. No HTML.
  2. Foldable — Indent blocks map naturally to fold regions (like list
nesting).
  1. Shared spec, shared implementation — markdown-it-dot-indent (npm) is being used to validate real-world effectiveness — npm publish, VSCode extension, and usage testing. If Obsidian adopts this rule, it can share the same package or spec, keeping updates and maintenance aligned across the ecosystem.
  2. Graceful fallback — Unsupported parsers treat it as text. Notes stay
valid.
→ Interactive demo + full spec (markdown-indent-proposal)
  • Tab / 4-space indent — Works in Obsidian (indent + layer grouping), but
breaks portability. Same file shows as code blocks in GitHub, VSCode, etc.
  • > blockquote nesting — Semantic mismatch (screen readers announce
“blockquote”); not suitable for non-quoted content.
  • Bullets + CSS to hide — Fragile, theme-dependent.
  • CommonMark spec issue 825 — Proposal: Native Indent for Markdown (spec discussion)
  • markdown-indent-proposal — Spec, demo, and implementation
We have other problems with spaces but not this one.
Four spaces (or 1 tab) create a codeblock in both obsidian and commonmark
This is one of the things that people hate the most of markdown and we are constantly asked to break away from it.
I think that if you get out of the markdown, Obsidian will no longer be Obsidian.
Anyway.
When I type tabs in the editor, it looks like an actual tab. It’s so cool that when I type tabs in the editor, it previews like the actual tab or the markdown indent I was expecting.
However, the actually saved characters were 4space.
There’s a compatibility issue as you said, right? Although it may be impossible, I created a markdown it extent NPM, and I requested Commonmark to define ..> as an indent syntax, but of course, I didn’t have high expectations that it maybe would accepted.
Actual Obsidian users I believe that many actual Obsidian users are using Indent, and I guess its usability is an issue, but I requested the function in the hope that my Mic-Down expansion proposal will be a useful idea for Obsidian.
You can press tab in the keyboard and it inserts a tab character
or
You can press tab in the keyboard and it inserts 4 spaces.
It’s controlled by this setting
Obsidian_72UZixuyAF
Regardless, in markdown, 1 tab char is equivalent to 4 spaces for indentation purposes.
but markdown common syntax 4space already reserved
4space is will apear to code block another preview well known
