MySecret — Transparent Vault Encryption for Obsidian | Obsidian Sync 100% Compatible
Disclaimer
Is this plugin open source? Ye
Community Directory: [Link](Plugin Obsidian)
Github: MySecret
:glowing_star: Overview
MySecret is a security and privacy plugin for Obsidian that automatically encrypts every file in your vault — notes, canvases, and attachments (images, PDFs, audio, video) — the instant they are written to disk.
It works like a one-way mirror between Obsidian and your hard drive: from inside Obsidian you see everything clearly — full-text search, graph view, links, Canvas. From outside — from the disk, from your cloud service, from whoever stole your laptop — there is only mathematical noise. Nothing readable.
Cryptographic keys exist only in your device’s RAM while the vault is unlocked. Not even the plugin developer can read your notes.
:glowing_star: The Breakthrough Advantages of MySecret
1. :magic_wand: Completely Invisible Encryption (Obsidian Keeps Working)
  • The Problem with Traditional Plugins: Plugins like Meld Encrypt turn your notes into unsightly blocks of encrypted Base64 code on screen. Because Obsidian cannot read the encrypted text, global search stops working, tags disappear, and the Graph View breaks completely.
  • The MySecret Solution: MySecret works quietly at the file system level (app.vault.adapter). When your vault is unlocked, Obsidian functions normally: your graph view connects your thoughts, quick-switcher finds any phrase in milliseconds, and canvases render smoothly. The moment files touch your hard drive, they are securely sealed in AES-256-GCM.
2. :counterclockwise_arrows_button: 100% Compatible with Obsidian Sync (No Re-download Loops)
  • The Graveyard of Encryption Plugins: Almost all encryption plugins break Obsidian Sync. Because in-memory notes are plaintext while cloud notes are encrypted, Obsidian Sync calculates mismatched checksums, assumes files are out of sync, and enters an endless loop of overwriting and re-downloading entire vaults.
  • The MySecret Solution: MySecret performs surgical runtime alignment on Obsidian’s hashing engine. Obsidian Sync compares the hash of the ciphertext in rest (matching the cloud byte-for-byte), while the user interface reads plaintext in memory. Zero sync loops, zero double encryption, zero bandwidth waste.
3. :camera_with_flash: Photos, Documents & Audio Are Also Encrypted
  • The Problem with Traditional Plugins: Traditional encryption plugins only encrypt markdown text. If you attach an image of a medical document, a private contract PDF, or an audio recording, those files are stored in plaintext in your attachments folder.
  • The MySecret Solution: MySecret encrypts every file type. Text notes use an armored container, while binary media (PNG, JPG, PDF, MP3, MP4) use a compact 32-byte binary header (MYSE). Your confidential attachments are just as protected as your written thoughts.
4. :backhand_index_pointing_up: Fingerprint & Face Unlock Everywhere (Even on Android!)
  • The Problem with Mobile Security: Obsidian Mobile on Android runs inside a restricted WebView where Google blocks native fingerprint APIs. Because of this hurdle, no other plugin has been able to offer biometric unlock on Android.
    • On Windows: Seamless native Windows Hello (fingerprint, facial recognition, or PIN) via DPAPI. Zero setup required.
    • On macOS & Linux: Native Touch ID and fprintd support.
    • On Android: An innovative, lightweight companion PWA bridge hosted for free on Cloudflare Pages. It uses ECDH P-256 ephemeral cryptography to verify your fingerprint in your mobile browser and securely unlock Obsidian in milliseconds—without your vault key ever leaving your device.
5. :unlocked: Your notes are yours — even without Obsidian, even without MySecret
  • The legitimate fear of trusting any plugin: ”What if this project is abandoned and I can’t open my notes?”
  • The MySecret Guarantee: Your files are encrypted with open, internationally standardized, universally implemented cryptographic specifications: AES-256-GCM (NIST SP 800-38D), Argon2id (RFC 9106, IETF Standard), and BIP-39 (the same standard used by the best hardware crypto wallets). These are not formats invented for this plugin — they are specifications published in thousands of books, implemented in thousands of independent software libraries. If MySecret disappeared tomorrow, you could decrypt your entire vault with:
    1. Python: A 15-line script using universal libraries (cryptography or pycryptodome + argon2-cffi). No Obsidian needed.
    2. Any modern web browser (fully offline): The native crypto.subtle API (Chrome, Firefox, Safari, Edge) can decrypt any note from a local HTML file.
    3. CyberChef (GCHQ’s cryptographic Swiss Army knife): Paste the base64 IV, Tag, and ciphertext directly using the standard AES-GCM recipe.
    4. OpenSSL, Node.js, Go, Rust: Any language with standard AES-GCM support can read and process your files. Your data is mathematically yours forever.
