When I was writing a note, my computer reboot because of blue screen.
After rebooting, I found the note was turned into red dots, no readable words listed.
Just wondering how I can fix this.
I searched the help document and googled, nothing was found.
Ctrl+Z didn’t help either.
I checked hexdump of the file,found that red dot was actually 00.
SO my notes was totally DESTROYED.
There is the “File Recovery” plugin, which you can try.
Go to the settings → File Recovery → Snapshots “View” → search for the title of your note. And hopefully you will see some previous revisions.
I also very highly recommend making sure you back up your notes occasionally.
Thank you so much ~
It really helps !
