My ipad mini continually downloads vault files and then deletes them
I have a mac, an iPhone, an iPad Pro and an iPad mini. Since the latest release, either App Store or test flight, of obsidian, all my devices read and write to the vault without error, except the iPad mini. I log into the vault and start downloading and it downloads the 1,850 files, then pauses, then starts deleting them from the iPad. I can watch the file count on the lower left corner go up, stop, then go sown, then go up then go down. If I lest it sit it will continue to load the vault files, then delete the fault files then load the vault files. I have deleted obsidian and cleaned out all files and loaded from the App Store and TestFlight and the result is the same. It makes obsidian unusable on the iPad mini cuz files i want to open are either there or not
Delete obsidian, reinstall obsidian, reboot, reset all setting. Everything short of a full nuke and pave
I have 363gb free on the iPad
How are you syncing? Obsidian Sync? iCloud? First step is to ensure it isn’t both at the same time.
If it’s iCloud, you need to set it to keep the files downloaded on the device.
