Multiple right-click menus can be opened simultaneously on selected cells
  • Shift+LeftClick a single cell, or select multiple cells (using keyboard shortcuts or mouse drag).
  • RightClick one of the selected cells open multiple context menus.
  • Either of the following stops the behavior after it has been triggered:
    • LeftClick one of the selected cells (it must be a cell, not an empty space).
    • Esc to clear the selection. If multiple context menus are open, the first Esc press clears the selection and closes the first context menu; subsequent presses close the remaining menus one by one.
  • LeftClick an empty space appears to clear the selection, but the context-menu issue remains. Furthermore, switching to another tab and then returning to the original tab restores the previous selection, and the problematic behavior continues.
I’ll open a separate BR regarding issue of the selection/focus being remade after switching tabs.
Did you read and follow the Troubleshooting Guide ? [Yes]
One right-click menu should be visible at a time on selected cells.
	Obsidian version: 1.14.4
	Installer version: 1.14.3
	Catalyst license: insider
	Insider build toggle: on
2026-10-03_135613
