When multiple Obsidian instances are running simultaneously, the following issues occur.
E:\>D:\soft\obsidian\obsidian-1.14.4\Obsidian\Obsidian.exe --user-data-dir=D:\soft\obsidian\obsidian-1.14.4\data D:\soft\obsidian\新建文本文档.md
E:\>
Updates disabled.
2026-10-06 16:24:06 Loaded main app package D:\soft\obsidian\obsidian-1.14.4\Obsidian\resources\obsidian.asar
CLI server error: Error: listen EADDRINUSE: address already in use \\.\pipe\obsidian-cli-rorange
at Server.setupListenHandle [as _listen2] (node:net:2306:21)
at listenInCluster (node:net:2437:12)
at Server.listen (node:net:2579:5)
at module.exports (D:\soft\obsidian\obsidian-1.14.4\Obsidian\resources\obsidian.asar\main.js:64:405)
at loadApp (D:\soft\obsidian\obsidian-1.14.4\Obsidian\resources\app.asar\main.js:313:3)
at Object.<anonymous> (D:\soft\obsidian\obsidian-1.14.4\Obsidian\resources\app.asar\main.js:473:12)
at Module._compile (node:internal/modules/cjs/loader:1937:14)
at Object..js (node:internal/modules/cjs/loader:2070:10)
at Module.load (node:internal/modules/cjs/loader:1658:32)
at node:internal/modules/cjs/loader:1450:12 {
code: 'EADDRINUSE',
errno: -4091,
syscall: 'listen',
address: '\\\\.\\pipe\\obsidian-cli-rorange',
port: -1
Received file path D:\soft\obsidian\新建文本文档.md
Can this pipeline name be changed to…
\\.\pipe\obsidian-cli-1.14.4-rorange
