Multi-paragraph list in callout followed by block ID rendered differently between live preview and reading mode when
Enter the following text (please remove the backtick):
> [!note] This quote doesn't have ID
> - This is a sentence.
> 	This is the next sentence.
> [!note] This quote has ID
^test
Y
Expect that the rendered callout between live preview and reading mode is the same.
In reading mode, if the callout has a block ID, then the 2nd sentence is rendered incorrectly.
Obsidian version: v1.5.12
Installer version: v1.5.8
Operating system: Darwin Kernel Version 22.6.0: Wed Jul 5 22:22:05 PDT 2023; root:xnu-8796.141.3~6/RELEASE_ARM64_T6000 22.6.0
Catalyst license: none
Base theme: light
Community theme: Things v2.1.20
I changed the title to more clearly describe the problem (was “Blockquote inconsistency between live preview and reading mode”) and edited the post slightly to match.
There are problems here but not the ones you are reporting.
I’ll open separate bug reports.
When you want to block link to multiline blocks (like lists) you need to place the identifier by itself after the block separated by a blank line.
In this case:
> [!NOTE] Title
> Contents
 ^blockid
