I used to use Zotero to markup PDF files, pulling the highlights into Obsidian for processing. However, these days, most of my sources have been converted into Markdown so I’d like to keep everything in Obsidian. My process uses multi-coloured highlighting of the text (to show the nature of the argument or use of other sources). Once done, for convenience I extract the highlights into a separate document.
I have found plugins that handle standard markdown highlights, but I’m looking for a combination of coloured markup AND then subsequent extraction, all in Obsidian. Anyone doing this? (I tagged this as Zettelkasten, but it’s more Zeteelkasten-ish!)
I don’t know how you’re currently doing your multi-colored highlights, but if you’re open to making them with Dataview inline properties and CSS, you can easily collate them within and across notes.
The CSS at that link should still work even though Obsidian has since begun deprecating the RGB color variables. If it matters to you, you can replace what’s shown thusly:
