It just does. Very annoying.
Very annoying when people don’t even try to fill out the bug report template.
They just do.
@ariehen’s perhaps unnecessarily snarky, but correct. Please follow the template when submitting bug reports. Thanks!
It appears when you first create a new topic in the #bug-reports category. I’m pasting it below:
We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with **community plugins and custom CSS** disabled and see if it's still reproducible. Alternatively, you can use the Sandbox vault (lower left corner `?` -> Open Sandbox vault).
If it's an issue with third-party plugins or themes, try contacting the author for help.
Mobile-specific bug reports should be filed here: <https://forum.obsidian.md/c/mobile/18>
**Once you've done the above, delete everything above this line.**
### Steps to reproduce
Starting from scratch, what are the steps to make the bug happen?
The fewer the steps, the better.
Type below: -->
### Expected result
What do you expect to see after carrying out the steps above?
### Actual result
<!-- Instead of the expected result, what happened? -->
### Environment
<!-- Which operating system are you using? -->
- Operating system:
<!-- Paste your debug info below, which can be accessed by Ctrl/Cmd-P, enter "Show debug info", and click "Copy to clipboard". -->
- Debug info:
### Additional information
Anything else you think would help our investigation, like a screenshot or a log file?
You can drag and drop screenshots to this box.
For large amount of text, try putting them into something like Pastebin.
Also search first before posting bugs or feature requests. Mouse cursor overlaps font size tooltip thing
