[Bug] Mobile settings pane blank or hidden
When tried to change config of window pull-down action, open setting and mobile pane is empty
Exiting app and reopening, then entire settings pane won’t show. (Looks like to shows up behind other content.)
Platform
[ x ] iOS
[ ] Android
Obsidian Mobile version: v0.0.xx
I took a video. Upload to Discord? Or somewhere else?
Does it happen without plugins and custom css off?
If yes, you could upload a (non-listed) video on YouTube and share the link here.
I seem to have the same problem on Android. When turning the mobile horizontal I can see part of the content, but can’t scroll sideways to see it all or change any settings.
So it turns out it was due to the theme. After switching theme the problem was solved, though I guess it would be easy for anyone with some css-skills to fix it within any theme.
