Hi, I use the Obsidian mobile app on Android A54.
What I’m trying to do:
I need to increase the width of the scrollbar.
It’s currently very small, and so light it’s almost invisible, and literally glued to the edge of the top-right screen. I can’t use it at all.
I’ve searched on the forum but found no solutions for the mobile app.
Maybe there are some CSS settings that can help?
Things I have tried:
I installed several themes, the scrollbar is the same on every theme.
I checked Android’s accessibility settings, but scrollbars are fine everywhere else on my phone.
(The screenshot has the Obsidian Default theme on Dark Mode, with 1362 words.)
ariehen
2
You could give a CSS snippet like this a try:
body.is-phone ::-webkit-scrollbar {
width: 18px; /* default is 12px */
This works in mobile emulation for iOS and Android, but it does not work on an actual iOS device. It may or many not work on Android. Worth a try.
Oh wow, thanks so much, it works perfectly!!
Even tried a few themes, it’s very good.
Here is the result:
Have a good day
ariehen
4
Wow! Good to know that works on Android devices.
system
Closed
5
