I do a lot of estimating and receive prices daily, I will put these in a daily not with a relevant tag, (they will normally be an external file link, occasionally Email dragged links too.) So I then want the link to show on the relevant category note e.g. stone.
I am no expert when it comes to Dataview, but i think you want to tag your data in a different way. #stone does not refer to a specific key-value pair, but to the whole page.
I was just refering to your example. In this example u have a key #stone, then a link [[Watercourse]] followed by a file link [Watercourse Price](...). I was assuming thats the format you use for price entries.
So (with the correct dataview annotation) you could have one or multiple daily notes having entries like this:
stone:: [[Some Link]][File1](file1)
stone:: [[Some Other Link]][File2](file2)
stone:: [[Another Link]][File3](file3)
or whatever.
And in your stone page you could collect all those entries like shown above.
A nitpick for clarity: [[Watercourse]] isn’t a backlink, it’s just a link; or more specifically an internal link aka a wikilink. Backlinks are links in other notes that point to the current note.
A simple non-DataView way to see more info would be to use an embedded search.
```query
tag:stone
But if you want to click the links in each entry, you’ll need to click the search result first.
I think I have been doing this wrong, by trying to put the information on a daily note. Where what I need to do is create a new note for every price quotation i get. then have another note for the filtered table results.
How you might best arrange things depends heavily on what you’re trying to do. Think about your end goal and work backwards from there, figuring out what you need at each step, and what would support that.
