Metadata array layout problem
Hello,
I’m havin a list in each note like Rx: (Rx_freq::[ [[S]], [[L]] ]), where S & L are the links to the other notes
Since one month this list doesn’t show properly anymore, but like this:
If i delete the brackets and put Rx: (Rx_freq:: [[S]], [[L]] ) the list shows again fine.:
But in this case i have to update all the lists within all my notes.
I can’t understand why list stopped showing. What could be a work around without changing every single note?
Sorry to bear bad news, but you might want to also consider that your first way of doing it isn’t an array. It’s a string.
Your second way, without the surrounding brackets, is an array.
