Thankyou … let me go take a look.
@Lithou so - had been modifying parts of the theme - and so to make sure i hadn’t broken anything - killed that theme and freshly installed cybertron from the directory.
I have enabled all my snippets - and nothing.
this is the snippet code I have
.tag[href="#notes/rough"] {
color : red;
  • and there are LOTS of #notes/rough tags the system
but sadly nothing.
any ideas i would welcome. (I did try a non nested tag - but no dice.)
my thanks in anticipation
/John
testing and noting that #important is coming through as different to how my own tag appears … is that an issue?
yeah its outdated this is my new css code for outliners
.graph-controls .tree-item,
  .outline>.tree-item{
    border:0;
  .tree-item{
    margin-left: .3em;
    border-left: 1px solid var(--text-faint);
    transition: all 0.3s ease-in-out;
    padding: 0;
  .graph-controls .tree-item-inner::before{
    display: none;
    content: " • ";
    margin-right: 4px;
have a great day
Thanks! I like the design and it looks so good.
I have some problems coloring hastags on hover. In preview mode, it already works, but in editor mode, the # has a different class (.cm-s-obsidian span.cm-hashtag-begin) than the tag itself. The following works for hovering over the the tag name, but the # will not be colored on hover in editor mode:
.tag:hover,
.cm-s-obsidian span.cm-hashtag:hover
  color: var(--text-hashtag-hover);
How can color the whole tag including # when hovering over either the tag name or #?
Anyone can help? This cannot work on the latest version anymore.
Can someone test css: @keyframes for .markdown-preview-view hr {} with your own animations.
Keyframe animations are not working after declaring the animation attribute with all the required values.
Hi! Discovered your css snippet - it’s awesome, thanks!
By the way I have a pattern when I’m embedding stuff in daily notes from like “progress” notes.
https://drive.google.com/file/d/1t6FZk82xjK3mNEZ-p0tWJ6oK1uxvaSUC/view
My apologize for Russian everywhere
So for me it was critical to hide also titles of links and I solved this via addition to your snippet:
/* remove embed title */
.markdown-preview-view.clean-embeds .markdown-preview-view > div.markdown-preview-sizer.markdown-preview-section > div:nth-child(2) {
  display: none
You may also provide this addition commented in your snippet
A post was split to a new topic: Difficulty with Obsidian CSS
Ok. CSS neophyte here and first posting. I am using the default theme. First off, I cannot find an obsidian.css file, but have added some snippets. Very elementary stuff. I am just looking for a way to display headings in color in the ‘editor’ mode. I added a snippet below that works in ‘preview’ mode for H1, H2, and H3, but not H4, H5, and H6 I have searched the forum with no luck. Any help appreciated.
h1 { color: #C731D2; }
h2 { color: #FABB88; }
h3 { color: #FF8888; }
h4 { color: #32D6CA; }
h5 { color: #CAE317; }
h6 { color: #FF8888; }
Hey there,
for coloring headers in preview and editor mode, I use this:
/******* HEADING COLORS *******/
.markdown-preview-view h1,
.cm-header-1
  color: var(--text-title-h1);
.markdown-preview-view h2,
.cm-header-2
  color: var(--text-title-h2);
.markdown-preview-view h3,
.cm-header-3
  color: var(--text-title-h3);
.markdown-preview-view h4,
.cm-header-4
  color: var(--text-title-h4);
.markdown-preview-view h5,
.cm-header-5
  color: var(--text-title-h5);
.markdown-preview-view h6,
.cm-header-6
  color: var(--text-title-h6);
You can either declare the variables I use as e.g.
.theme-dark
--text-title-h2: #eadfbd;
or insert your RGB codes directly.
That worked perfectly. I just created a snippet with that code with color adjustments. Thanks.
Hi, is there a plugin or a CSS snip that trigger through command like “Create a Table of Content” that make H1 to H2 normal black bold but H3 to H4 gray bold like normal H6. And the content under H3 or H4 is fold but content under H1 to H2 is unfold that resembling like a table of content in a book. I hope everyone understand what I mean.
I really appreciate this clean-embed everywhere snippet. It’s not working with the new live preview feature in the current beta though. Has anyone tinkered with it to get it working?
This should be an easy fix. The snippet is targeting embed classes that are nested in a .markdown-preview-view class, but in live preview mode you’re working with .markdown-source-view as the parent class. Swapping the latter with the former should fix the problem.
How do I get the cursor to not blink though?
Also, is there documentation for messing with the cursor? I didn’t see it anywhere on the obsidian site.
@derekvan: you can also try @smurfman111’s snippet that works in both CM5 and CM6/Live Preview.
Hi, am i missing something? This code is not making embedes inline
![test] ![test2]
They are displayed on different lines.
Block references are working perfectly and are on the same line. But I, unfortunately, you can’t export them to DOCX at the moment
![test1^block] ![test2^block]
@baxterqc: here a is a snippet by @smurfman111.
