Create a mermaid erDiagram:
erDiagram
	FOO ||--|{ BAR :baz
Switch to Preview
Diagram looks good
Switch back to edit
Open new tab next to in preview mode (ctrl-click the edit button)
Accents on the diagram dissappear
Close other tab
Accents re-appear
Accents should always be there
They are not
  • Operating system: Ubuntu 18.04
  • Obsidian version: 0.8.15
Possibly a weird upstream bug.
  1. Use the following mermaid sequence diagram:
sequenceDiagram
	participant User
	participant Service
	User ->> Service: yo do dis ding
	Service-->>User: gotshu
	User -->> Service: wassupp
  1. Toggle to Preview, notice the arrowheads are displaying
  2. Toggle back to Edit, then open Preview to the side
  3. Notice the arrowheads are gone
To see the arrowheads in the preview even with split mode.
Arrowheads are not displayed.
  • Operating system: Win 10
  • Obsidian version: 0.12.12
In split view:
With only Preview on:
While the screenshot is with custom CSS, I tried also without and it had no effect.
  1. create note
  2. add mermaid code block like this:
```mermaid
classDiagram
	Klasse o-- Klasse2 : Aggregation
(ignore the backslash)
3. export as pdf
pdf with the mermaid graph with the correct arrow types
any arrow type will be removed
AubTCxPGJS
  • Operating system:
    Windows 10
  • Obsidian version:
    0.11.13
Hello. Can you guide me how to fix this? I can’t get it.
  1. Create following diagram
sequenceDiagram
Alice->>Bob: Hello!
Bob-->>Alice: Hello back!
  1. Export to PDF and open.
Arrows should be visible in PDF.
Arrows are cut off
In Obisidian, everything looks good
PDF Export settings:
  • Obsidian version: v0.12.15
  1. Add the following mermaid chart to a note:
```mermaid
flowchart
	step1[Some Step Here]
	step2[Another Step Here]
	step1 --> step2
  1. Toggle between reading mode and editing mode until the arrow heads disappear. You may also need to go into and out editing the block with live preview. It will periodically no longer render the directional arrow heads between steps.
It always renders the arrow heads.
Screenshot from 2021-12-28 08-47-45
Sometimes it will not render the arrow heads.
Screenshot from 2021-12-28 08-47-37
  • Operating system: Pop! OS (Linux)
  • Debug info:
	Obsidian version: v0.13.14
	Installer version: v0.13.14
	Catalyst license: none
	Legacy editor: off
	Safe mode: off
	Plugins installed: 0
	Plugins enabled: 0
@WhiteNoise FWIW, I did search but this thread didn’t show up. :man_shrugging:
Also, this is likely not an upstream bug, or if it is it has since been patched. When copying the graph into https://mermaid.live it has no issues rendering the arrow heads, and even in Obsidian it periodically can render them just fine. See above repro steps for potential causes.
I suspect one of the scenarios when loading in Obsidian does not properly initiate the graph.
In my case, when I turn the “use legacy editor” button on, the “mermaid arrow” show well in “reading view”. In the contrary, those arrows all disappeared.
I think that is a incompatibility problem between new editor mode and plugin.
In other Apps, like “Typora”, did not have this “mermaid arrow” issue.
