Md文档中插入base,在实时预览模式下,base显示为源代码
Y
Insert base into document md and preview it in real-time
base is displayed as source code and must be clicked once outside the document interface to display as real-time preview
Obsidian version: v1.9.14
Installer version: v1.9.14
Operating system: Windows 10 IoT Enterprise LTSC 2021 10.0.19044
Language: zh
That’s how
```base
code blocks work. Your cursor needs to be out of them for the base to render. Add an extra line before or after the code block so that you can move your cursor outside the base block.
You can also embed a base, ![[base name.base]], or a specific view.
https://help.obsidian.md/bases/create-base#Embed+a+base
You’re right, I added an extra blank line before the code block, and the real-time preview took effect. Thank you
