I’ve tried this with all core plugins off and only the the vim keybinding activated and everything else as is the default.
  1. Create or move into a file
  2. Write text in it that has brackets (e.g. hello(world))
  3. Try to use any function of vim that requires the matching bracket. For example pressing % in normal mode while on a bracket, or being in-between the brackets and pressing vi( in normal mode.
The cursor moves to the matching brackets/text in between them is highlighted.
Nothing happens and the console logs the following errors:
TypeError: cm.scanForBracket is not a function (cm-addons.js:993)
    at selectCompanionObject (cm-addons.js:3999)
    at Object.textObjectManipulation (cm-addons.js:2136)
    at Object.evalInput (cm-addons.js:1587)
    at Object.processMotion (cm-addons.js:1297)
    at Object.processCommand (cm-addons.js:1272)
    at cm-addons.js:986
    at runInOp (codemirror.js:3929)
    at CodeMirror.operation (codemirror.js:8615)
    at cm-addons.js:980
    at doHandleBinding (codemirror.js:7129)
Uncaught TypeError: cm.scanForBracket is not a function (cm-addons.js:3999)
    at cm-addons.js:986
    at cm-addons.js:980
  • Obsidian version: v0.12.4 (with installer version v0.11.9)
Boostnote used to have the same problem & they posted the solution (for them) in the issue
There’s a plugin that activates it. (not sure about %, but things like di( and ya[ work with it)
Oh nice, I found it: GitHub - mrjackphil/obsidian-add-codemirror-matchbrackets: This plugins adds matchbrackets.js which allows to use `di[` or `ya(` commands in Vim mode
I still think that this is a bug that should be fixed in the core
will be included in 0.13.8.
