Markdown links work in FROM but not in WHERE
Great plugin, small problem:
LIST FROM #someTag WHERE key = [[]]
does not work if using markdown links instead of wikilinks. this.file.link doesn’t help.
However LIST FROM #someTag AND [[]] will work using either wiki or markdown links, so it seems something is wrong with the WHERE filter being aware of internal markdown links.
Under settings: Files & links set use [[wikilinks]] to false
A list of files that have key:: current file
nothing
  • Operating system: Windows 11
  • Debug info:
    Obsidian version: v0.14.2
    Installer version: v0.12.5
    Operating system: Windows 10 Pro 10.0.22000
    Legacy editor: off
    Community theme: Blue Topaz
    Safe mode: off
    Plugins installed: 11
    Plugins enabled: 8
    1: Advanced Tables
    2: Dataview
    3: Natural Language Dates
    4: Quick Explorer
    5: Recent Files
    6: Citations
    7: Excalidraw
    8: Advanced Slides
Custom theme: for cosmetic issues, please first try updating your theme to latest. If still not fixed, please try to make the issue happen in the help vault or disable community theme and snippets.
Community plugins: for bugs, please first try updating all your plugins to latest. If still not fixed, please try to make the issue happen in the help vault or disable community plugins.
wrong place to post. This is for obsidian core only.
