Markdown Link after footnote is not handled properly
  1. Untick “Use Wikilinks” in “Files and Links” section of settings
  2. Add a footnote to text - [^1]
  3. Add the footnote text - [^1]: [[Link]]
  4. Delete the last two square brackets “[[Link” and the same file should be suggested in the search.
  5. Press enter and the link will be placed, but it will not be dynamic.
Y
[^1]: [link](link.md) is a clickable link that changes
[^1]: [link](link.md) was just plain text
Obsidian version: v1.3.7
Installer version: v1.3.5
Operating system: Windows 10 Education 10.0.22621
Catalyst license: none
Legacy editor: off
Community theme: Everforest v0.0.0
Plugins installed: 22
Plugins enabled: 18
1: Obsidian Link Converter v0.1.4
2: Readwise Official v2.0.1
3: Excalidraw v1.9.12
4: Text Extractor v0.4.6
5: Periodic Notes v0.0.17
6: Calendar v1.5.10
7: Note Refactor v1.7.1
8: Paste image rename v1.6.1
9: Dataview v0.5.56
10: Smart Random Note v0.2.1
11: Annotator v0.2.10
12: Frontmatter Tag Suggest v0.4.1
13: Tag Wrangler v0.5.11
14: Omnisearch v1.15.2
15: Footnote Shortcut v0.1.2
16: Citations v0.4.5
17: Reading Time v1.1.1
18: Janitor v1.0.7
Is it clickable in Reading View? hI assume you’re in Live Preview).
I get a clickable link on iPadOS in both Live Preview and Reading View.
Your debug info shows plugins enabled. I realize you may have generated the debug info before or after troubleshooting, but just to double-check: did you turn on restricted mode and restart Obsidian?
FWIW, I also get clickable links in live preview and reading mode with this dummy text:
Link in a footnote: ^[[[link]]]
Another simple footnote[^1].
And with a different link format[^q]
  [^1]: here is a link to the file [[link]]
  [^q]: link to [the same file](link)
Tried the sandbox vault? Same outcome?
I think this is a similar issue to what I described in the following bug report:
Similarly to HTML elements, links don’t display as expected in Live Preview if they are the first thing in the footnote content. That may be why it was not reproduced. I was able to reproduce this on v1.3.7:
[^1]: . [link](https://www.example.com)
[^2]: [link](https://www.example.com)
