No option to begin conversion. I see this on two different laptops.
Is this a problem only I’m facing?
I’m moving this to #help. Have you been able to figure it out? Are you using any custom css and/or have you zoomed in accidentally?
Hasn’t been resolved. I updated with the latest install file, disabled custom css; no dice.
@yashvirdalaya in that case please open a #bug-reports, we need a bit more info to narrow down the issue and try to reproduce this, so please don’t forget to use the template.
Your obsidian is just in zoomed format.
Press Cntr + - few times and your problem will be solved.
Cntr + -
