Management Consultant Vault Setup
Hi All!
I am a long time obsidian user but mostly in the academic field using vaults for higher level education as well as my PKM for writing and general learning.
But I am trying to incorporate the use of Obsidain into my work. Can any share their vault set ups for client meetings/project management but in the business context? I see a lot of PM around tech which is not really my area.
Any insights or feedback are appreciated
Not sure if my setup can help you, but take a look at it. You might be able to modify it to suit your case, or take some aspects you like.
