Making aliases using Templater dynamic commands with multiple parameters
I want to make an alias using Templater’s dynamic commands (<%+ ... %>) with multiple parameters, but it doesn’t work well, as I will describe below.
It works well when the command has only one argument. For example:
aliases: <%+ tp.date.now("YYYY-MM-DD") %>
(This example might look strange, but it is for an illustration purpose only)
Result (= what I see after switching to the reading mode):
However, it doesn’t work when it has multiple arguments. For example:
aliases: <%+ tp.date.now("YYYY-MM-DD", 1) %>
Result:
It looks like the parser recognizes the comma separating the arguments "YYYY-MM-DD" and 1 as a delimiter separating two aliases. In other words, it appears to interpret the above YAML frontmatter as
aliases:
  - <%+ tp.date.now("YYYY-MM-DD"
  - 1) %>
I tried enclosing the whole command with quotes as below, but I’ve got the same result.
aliases: '<%+ tp.date.now("YYYY-MM-DD", 1) %>'
Result:
I also found that this problem doesn’t occur for non-reserved keys
(see here for the list of reserved keys).
For example:
key: <%+ tp.date.now("YYYY-MM-DD", 1) %>
Result:
So I suspect this problem is related to how Obsidian parses the alias metadata.
How can I fix this? Thank you.
Specs
  • macOS Venture (version 13.2)
  • Obsidian version 1.3.5
  • Templater version 1.16.0
In general, using dynamic commands as an alias is a bad idea. If you just use the normal command braces <% ... %>, the alias will be created on file creation and will not shift.
What notes are you creating that you want a shifting alias depending on the day?
Thank you for your reply!
As I wrote, the above example is only for simplifying the explanation.
I thought it would be better not to show what I’m actually working on because it involves my custom user functions and looks a little bit messy, but I show a simplified version below:
theorem:
  type: theorem
  title: Cauchy-Schwarz inequality
  label: cauchy-schwarz-inequality
aliases:
  - <%+ tp.user.make_latex_alias(tp, tp.frontmatter.theorem.type, tp.frontmatter.theorem.label) %>
  - <%+ tp.user.make_natural_language_alias(tp, tp.frontmatter.theorem.type, tp.frontmatter.theorem.title, 'en', tp.frontmatter.theorem.number) %>
I’m making a template for mathematical theorems, definitions, lemmas, and so on. In the frontmatter, it has theorem metadata, which has several sub-metadata:
  • type: specifies the type of the note, such as definition/theorem/lemma/etc
  • title: the title of the theorem
  • label: used to generate a LaTeX-style label (e.g. thm:cauchy-schwarz-inequality) in order to make it easier to convert LaTeX documents that I currently have into markdown, and also to convert markdown to LaTeX in the future
After filling in these metadata, I want to automatically generate aliases using the metadata. In this example, they would be like
  • an alias in the style of LaTeX labels, made from type and label: thm:cauchy-schwarz-inequality
  • a human-friendly alias in English, made from type and title: Theorem (Cauchy-Schwarz inequality)
tp.user.make_latex_alias and tp.user.make_natural_language_alias are my custom user functions to make these aliases.
I want the aliases generated dynamically. In other words,
when I modify the theorem metadata, I want the aliases to change automatically according to the modification that I made to the metadata.
That’s why I need dynamic commands here. If I used the normal commands (<% ... %>), I couldn’t realize such a dynamic behavior.
