macOS right click
Right click shows both macOS native menu and obsidian menu when the “Native Menus” option is closed.
Obsidian version: v1.8.7
Installer version: v1.8.4
Operating system: Darwin Kernel Version 24.1.0: Thu Oct 10 21:03:15 PDT 2024; root:xnu-11215.41.3~2/RELEASE_ARM64_T6000 24.1.0
Community theme: Things v2.1.20
Snippets enabled: 1
Plugins installed: 62
Plugins enabled: 19
1: Linter v1.27.1
2: Auto Link Title v1.5.4
3: Easy Typing v5.5.5
4: Latex Suite v1.9.7
5: Omnisearch v1.25.1
6: Image Converter v1.2.3
7: Templater v2.9.1
8: Calendar v1.5.10
9: TimeStamper v1.3.0
10: Minimal Theme Settings v8.1.1
11: Style Settings v1.0.9
12: Simple CanvaSearch v1.0.0
13: Number Headings v1.16.0
14: File Cleaner Redux v1.1.2
15: Size History v1.0.0
16: Homepage v4.0.7
17: Git v2.28.2
18: Tasks Calendar Wrapper v0.3.1
19: Kanban v2.0.51
Is closed?
yes the native menus is closed. The macOS native menu only shows simple cut copy paste option.
I guess macOS is still monitoring if I am using a text editor and selecting some words. If so, it still pop up the basic menu (like Look up the selected word, cut copy and paste).
I cannot reproduce. Note that he has plugins enabled.
Installer version: v1.6.5
Operating system: Darwin Kernel Version 24.2.0: Fri Dec 6 18:51:28 PST 2024; root:xnu-11215.61.5~2/RELEASE_ARM64_T8112 24.2.0
Plugins installed: 0
Plugins enabled: 0
This is an issue with all Obsidian 1.8 and 1.7.5+ installers, there was a bug in electron (our upstream library) that affects right-click on macOS. We will be updating as soon as the issue is resolved in electron.
Thanks! Yeah I do not have this issue before a recent upgrade. So it should be a problem introduced in recent upgrade
