MacOS -- Note view moves to top on clicking
  1. Click on any window (non-obsidian or obsidian) or tab. Assume you have Note A and Note B – both scrolled to the bottom.
  2. Click Note A, nothing happens when you clilck on Note B. Upon clicking on Note A from B (Or any window or tab obsidian/non-obsidian) it reverts
Yes. Same behavior persists on both using the plugin restricted mode, snippet/free/default theme as well as within sandbox mode.
I expect both Note A and Note B to be in the same position regardless of how they are clicked into
Well – which ever note I click back to Jumps back up to the beginning.
Enviroment for Sandbox
Obsidian version: v1.4.16
Installer version: v1.4.16
Operating system: Darwin Kernel Version 23.1.0: Mon Oct 9 21:28:12 PDT 2023; root:xnu-10002.41.9~6/RELEASE_ARM64_T8103 23.1.0
Legacy editor: off
Enviroment for my normal vault
Legacy editor: off
Base theme: light
Community theme: Ultra Lobster v1.0.0-1.0
Plugins installed: 39
Plugins enabled: 35
1: Note Refactor v1.7.1
2: Tag Wrangler v0.5.11
3: Auto Classifier v1.1.1
4: Auto Link Title v1.4.1
5: Better Word Count v0.10.0
6: Homepage v3.4
7: Linter v1.19.1
8: Topic Linking v0.1.7
9: QuickAdd v1.2.1
10: Whisper v1.5.1
11: Natural Language Dates v0.6.1
12: Footnote Shortcut v0.1.2
13: Canvas Links v1.1.4
14: Advanced Slides v1.20.0
15: Copilot v2.4.0
16: Link Exploder v0.3.0
17: Optimize Canvas Connections v1.0.0
18: Omnisearch v1.17.1
19: Highlightr v1.2.2
20: Callout Manager v1.0.1
21: Settings Search v1.3.8
22: Minimal Theme Settings v7.2.2
23: Calendar v1.5.10
24: Zotero Integration v3.0.7
25: Simple CanvaSearch v0.1.0
26: Kanban v1.5.3
27: Smart Connections v1.6.34
28: Dataview v0.5.56
29: Find orphaned files and broken links v1.9.1
30: Templater v1.16.4
31: Pandoc Reference List v2.0.24
32: Citations v0.4.5
33: Obsidian Enhancing Export v1.9.2
34: Pandoc Plugin v0.4.1
35: Remember cursor position v1.0.8
“Remember Cursor Position” plugin has been used to see if it works, BUT the same behavior still persists.
Forgot to share, here are video links of the bug itself
It seems this occurs when macOS’s “Full Keyboard Access” is enabled. I haven’t checked this myself.
via Discord
Yes, my apologies. This was my (same guy’s post) – have not gotten around to updating the post yet. As of now the issue seems solved.
Thank you again for the help!
