M1 Macbook Pro 16" MacOS Tahoe 26.3 (latest)
Secondary Display (External Monitor) aligned above my Macbook screen.
Macbook screen resolution adjusted to look like lower res.
Obsidian is positioned on External monitor, set as fullscreen.
Try to click top area UIs. (tabs or top of sidebar buttons)
Better reproduced when trackpad ‘press to click’ than ‘tap to click’
Yes. It also reproduces on Sandbox Vault
Tabs selected
shows Drag UI
Obsidian version: 1.12.4
Installer version: 1.5.12
Operating system: Darwin Kernel Version 25.3.0: Wed Jan 28 20:53:15 PST 2026; root:xnu-12377.81.4~5/RELEASE_ARM64_T6000 25.3.0
Language: ko
Only reproduced when monitor aligned on top of my macbook (move pointer upward to secondary display) AND macbook resolution changed. Only happens on external monitor, app is fullscreen.
when file explorer list is long, you can see a file on bottom is highlighted briefly.
