Losing Sync connection on Android
Trying to Sync an existing Vault to Android
I have tried connecting to my vault, the Android client appears to be borked, looses the connection every time the app is closed / reopened, tried to open a bug report, that did not seem to work either.
I looked on the https://obsidian.md/ site for release notes for the Android client, I can’t find anything, there is a link to the “Google Play Store” but that is (as usual with Google) useless.
C
It sounds like something may be deleting Obsidian’s configuration. Do you use any kind of storage cleaner app or anything like that?
I renamed this thread to make clear the specific problem you’re facing. (Was “Is Android a Supported Platform?”)
Here on the forum? What happened?
