I can’t see that this has been posted (after 10 minutes search). Sorry if it has.
Step 1: [[ to link to heading or block in another document.
Step 2: Document title shows in pop-up for selection using either # for heading or ^ for block.
Step 3: clicking on either # or ^ opens document in scrolling window.
But: if document is too long then it simply ends and there is no scope to link to any point beyond the cut off. I am trying to link to a document containing an A-Z of terminology and it goes as far as ‘H’.
We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
  • Operating system:
  • Obsidian version:
I don’t undestand. Can you post a screen recording.
Is this your problem
That seems to be it! Sorry to waste your time!!
