Local outside-vault picture not displayed as it did before in live-preview mode
I don’t know that Obsidian exactly since when didn’t display local outside-vault pictures as it did before. Such picture can still be displayed correctly but only when not embedded in a callout/table. Otherwise, they are displayed like a broken link.
The reason why I’ve stored the multimedia files outside rather than inside the vault is to keep the vault size as small as possible for easier backup.
I actually have no idea whether this is a bug or there is some new way of refering to a local outside-vault file, that has been developed in replacement of the old markdown link. But I did have tried to google my problem and search within this forum with no answer found. Actually, such issue has apparently never been encountered/reported by anyone. So I now report this as an issue or whatever to capture the developers’ and other users’ attention. Hope somebody could help me out.
![](f:\folder-accessible.webp)
outside-vault pictures embedded in a table not shown as it were
[!info] outside-vault picture embedded in a callout
Yes.
The pictures should be displayed normally as they were.
Any such picture embedded in a callout/table is displayed like a broken link.
Obsidian version: 1.12.7
Installer version: 1.12.7
Community theme: Prism 3.7.0
Plugins installed: 38
Plugins enabled: 33
1: Tag Wrangler v0.6.4
2: Text Snippets v0.1.2
3: Tasks v7.20.0
4: Reminder v1.1.19
5: Templater v2.12.1
6: PDF break page v1.0.0
7: Callout Toggles v1.2.1
8: Blockquote Levels v1.1.0
9: Style Settings v1.0.9
10: Better footnote v1.0.1
11: Automatic Table Of Contents v1.7.3
12: Better Export PDF v1.11.0
13: Query Control v0.7.13
14: Meld Encrypt v2.4.2
15: Callout Manager v1.1.0
16: Code Editor Shortcuts v1.14.0
17: Equation Citator v1.2.4
18: Footnote Shortcut v0.1.3
19: Better Search Views v0.3.0
20: Broken Links v1.2.2
21: Local Images Plus v0.16.3
22: Quiet Outline v0.5.12
23: Highlightr v1.2.2
24: Regex Find/Replace v1.2.0
25: Easy Typing v5.5.15
26: Auto Hide Cursor v1.1.0
27: Enhancing Export v1.11.1
28: Extract PDF Annotations v1.9.4
29: Copy Block Link v1.0.4
30: Copy Section v1.2.4
31: Another Quick Switcher v14.5.1
32: BlazeJump v1.0.7
33: Scrolling v1.3.8
Broken-displayed pictures embedded in tables and in callouts in v1.12.7
Correct display in v1.6.7
The picture is stored outside the vault but definitely accessible.
I believe you need to use file:/// before the path. e.g.
![](file:///f:\folder-accessible.webp)
I can’t check on Windows at the moment, but these (for example) work on macOS:
![clear recents.png](file:///Users/ME/Desktop/clear%20recents.png)
> [!NOTE]
This is the type of link created when holding down Ctrl/Option and dragging an image into a note. https://obsidian.md/help/drag-and-drop#Dragging+from+outside+Obsidian
Some Windows and macOS examples in this topic:
Yes, the code “file:///” works out. Thanks a million, buddy!
~~Drag the file to Obsidian while holding down the Ctrl key to obtain a complete link.~~
Sorry, my browser made an error translating the webpage. I didn’t see @ariehen mention Ctrl.
You’re right. I already learnt this from the upper ladder. Thanks.
