LLM Wiki Tutor: a pixel cat teaches Obsidian basics and walks you through building your first LLM Wiki
Disclaimer
Is this plugin open source? Yes (MIT)
Community Directory: https://community.obsidian.md/plugins/llm-wiki-tutor
Hi everyone,
Andrej Karpathy’s LLM Wiki idea is simple: you drop files into a raw folder, an AI keeps organized notes in a wiki folder, and a rules file tells it how. But the guides assume you already know Obsidian and are comfortable in a terminal.
LLM Wiki Tutor is a hands-on course for everyone else. A pixel cat walks along the bottom of your workspace, explains one idea at a time, points at the exact folder or button, waits until you have actually done it, and does it for you if you get stuck. Short lesson notes build up in the side panel as it talks.
There are two courses:
  • Obsidian Basics (6 lessons, about 30 min): the screen, notes as files, Markdown, links and Graph view. You can skip it if you already know Obsidian.
  • Build an LLM Wiki (9 lessons, about 50 min): the raw folder, the wiki folder and AGENTS.md, then ingest, query and lint, and how to change the rules.
The lessons replay what an AI would write, so you don’t need an AI, a key or an account to finish them. In the last lesson you do one real ingest with the AI you already use, either through the Claude desktop app or by copying a prompt into any chat AI and pasting the answer back.
Privacy and safety: the plugin makes no network requests and never calls an AI itself. It only writes inside one practice folder, previews every write first, and sends anything you reset to the trash. It uses the clipboard only when you press a Copy button.
The folder layout matches the Karpathy LLM Wiki plugin, so you can keep going with that when you outgrow the tutor.
Korean, English and Simplified Chinese. Desktop only.
Install: Settings → Community plugins → Browse → “LLM Wiki Tutor”
Source & issues: https://github.com/elliott-json-park/obsidian-llm-wiki-tutor
Feedback is very welcome. I’d especially like to hear where you got stuck, and whether you made it to the last lesson.
