When a note containing two or more consecutive callouts is transcluded into another note, the callouts render flush against each other with no vertical spacing in Live Preview. The same transclusion renders correctly in Reading View, confirming the callout CSS itself is not the issue β the fault is isolated to how Live Preview renders callouts inside transclusion block widgets.
This issue seems to be a revival of this bug.
- Create
callouts.mdcontaining two consecutive callouts - Create
transclusion.mdand add![[callouts]] - Open
transclusion.mdin Live Preview - Observe the callouts are bunched with no gap between them
- Switch to Reading View β spacing is correct
Did you follow the troubleshooting guide? Yes
Consecutive callouts in a transclusion render with consistent vertical spacing in both Live Preview and Reading View.
Consecutive callouts in a transclusion are flush against each other in Live Preview only.
Obsidian version: 1.13.4
Installer version: 1.12.7
Operating system: Darwin Kernel Version 24.6.0: Tue Apr 21 20:18:13 PDT 2026; root:xnu-11417.140.69.710.16~1/RELEASE_ARM64_T8132 24.6.0
Catalyst license: vip
Plugins installed: 10
Plugins enabled: 0
Since Reading View renders the spacing correctly, the fix likely lies in how Live Previewβs transclusion block widget handles sibling callout elements β possibly that the cm-line spacer divs injected between native callouts are absent when callouts are rendered inside a transclusion widget. Comparing the DOM output of both contexts may help isolate the discrepancy.
