- Add an enumerated list to a new. Start the numbering at 2 (not 1)
- Check the list in live-preview (moving the cursor away from the list)
- Check the list in read view
LivePreview and Read view renders the lists (more or less) identical.
LivePreview treats the list as a numbered list. (I.e. colour of number is different from text, indentation is correct) Read view does not treat the list as a numbered list. (I.e. plain text)
- Operating system: macOS
- Debug info:
Obsidian version: v0.13.19
Installer version: v0.12.12
Legacy editor: off
Base theme: light
Community theme: Minimal
Snippets enabled: 3
Safe mode: off
Plugins installed: 4
Plugins enabled: 3
1: Advanced Tables
2: Dataview
3: Minimal Theme Settings
Custom theme: for cosmetic issues, please try to make the issue happen in the help vault or disable community theme and snippets.
Community plugins: for bugs, please try to make the issue happen in the help vault or disable community plugins.
