Open a new note, switch to any non-default input language layout, start typing.
Inserted characters correspond to the currently active input language layout.
Inserted characters correspond to the US English layout.
  • Operating system: Linux (Fedora 34, KDE spin)
  • Obsidian version: 0.12.15
I have tested this with German and Russian layouts. The OS/DE correctly indicates that the input layout has changed, all other programs (browsers, editors, terminals etc) work as expected.
I have tested both the Flatpak and the AppImage versions of Obsidian, with the same outcome.
@koala , @argentum can you repro this?
No, I can’t repro. We had a similar issue before which I couldn’t repro, but there was something Licat fixed.
Me neither. I often switch between German and English and I can’t say I’ve seen this.
I will try to repro this using different DE, and will update the topic with the results.
@argentum @koala which distro/DE are you using?
I’m on Ubuntu 18.04 using i3 and the Obsidian AppImage
I’m on Manjaro Linux with KDE Plasma. I use the AppImage.
Ok, I have repro’d this on KDE once again, and then tested with other WM/DEs: everything worked just fine under XFCE, Wayfire and Sway, using same Obsidian install (Flatpak).
I have rebooted and tested on KDE again, this time it started working. I can’t really say what it was: apparently some temporary glitch. In any case, this seems to be gone now, so please feel free to close the topic.
Thanks!
