Links to images in other disc of pc
I have Obsidian 1.1.19 and Win 10
I use this code to link an image: ![text](C:\folder\filename.ext)
When the image is on disk C: the image is showed, but if the image is on disk D: or E: an error is showed.
How can I do?
Sorry for my bad english
Thanks in advance
Filippo
Hi, I edited your post. When you post Markdown, surround it with backticks ` so it shows up properly.
Like this:
`![text](C:\folder\filename.ext)`
If you hold alt while dragging an image into Obsidian, it will make a full absolute path to the link automatically for you. You can also type out the full path by using file:///
For example:
![text](file:///D:/folder/filename.ext)
\ backslashes can cause problems. So sometimes you have to use forward slashes. / or double backslashes \\.
And if you have spaces in your names, you need to use %20 or put your link inside <link>:
example “file name.ext”:
![text](file:///D:/folder/file%20name.ext)
or
![text](<file:///D:/folder/file name.ext>)
(I’m on MacOS. I hope I didn’t make any typos. I can’t test these.)
Thank you very much!
I had problems to manage the filename spaces.
