Links to Headers in Multiline Comments
  1. Create a new note in Obsidian.
  2. Paste the following content into the note:
# Check Out this Obsidian Bug
[Link](https://www.example.com/new/link/broken)  %%
# H1
## H2
By [A1](https://www.example.com/idiot/1) [A2](https://www.example.com/idiot/2) and [A3](https://www.example.com/idiot/3)
WASHINGTON—GPT Generated Brain Rot
And fluff
Copyright ©2025 Front Company, Inc. All Rights Reserved.
WTF?
  1. Try to create a link to the same document, and you will see the quick link screen displays the headers inside the comment.
  2. See the third image below for a demo.
Y
The software shouldn’t suggest that you link to headers inside a comment.
You are suggested to create links inside a comment.
OS: MacOS
Obsidian Version: 1.7.7
This behavior seems related to how multiline comments with headers are processed. Screenshots are attached to illustrate the issue.
I posted a related, but different bug here.
Hybrid Mode
Reading Mode
Suggested Link to Comments
