Links ending with sigma (Σ) do not work
I do not know. Mayby an Obsidian update
Did you follow the troubleshooting guide? [Y/N] Y
Yes. I also made a new Vault with similar plugins.
All internal links to work. Some internal links and especially some of those wher they link to notes that have #επαφή as a tag do not recognise the note and ask me to create new note.
Some internal links and especially some of those that they link to notes that have #Επαφές as a tag do not recognise the note and ask me to create new note.
Obsidian version: v1.7.4
Installer version: v1.4.13
Operating system: Windows 10 Pro 10.0.22631
Base theme: light
Community theme: AnuPpuccin v1.5.0
Plugins installed: 35
Plugins enabled: 32
1: Calendar v1.5.10
2: Kanban v2.0.51
3: Checklist v2.2.13
4: Tasks v7.11.1
5: Reminder v1.1.15
6: Mind Map v1.1.0
7: Excel to Markdown Table v0.4.0
8: Dataview v0.5.67
9: CardBoard v0.7.9
10: QuickAdd v1.11.1
11: Status Bar Pomodoro Timer v0.1.14
12: LanguageTool Integration v0.3.7
13: Style Settings v1.0.9
14: Extract PDF Annotations v1.5.0
15: Omnisearch v1.24.1
16: Commander v0.5.2
17: Highlightr v1.2.2
18: Markdown Formatting Assistant v0.4.1
19: DataLoom v8.16.1
20: Day Planner v0.24.0
21: Image Toolkit v1.4.2
22: Pandoc Plugin v0.4.1
23: Diagrams v1.5.0
24: Enhancing Export v1.10.8
25: Custom Frames v2.4.7
26: Editing Toolbar v2.4.16
27: Natural Language Dates v0.6.2
28: Excalidraw v2.5.2
29: Tracker v1.14.0
30: Review v1.6.5
31: Advanced Tables v0.22.1
32: Heading Level Indent v1.0.3
You can see that some internal links that were working before are now suddenly not working
This may or may not fix the issue for you, but the Electron installer is incompatible with the version of Obsidian you are using and it needs to be updated by downloading the full installer package from the Obsidian website:
@anon45210282 I have done what you recomended but I have the same problem again!
Do you have mentioned files on your drive or did they disappeared?
@ViciousSquid The files are there. I can open them via Notepad
Also I can open them via Obsidian but I cannot use a link in any note to direct me to those files
Maybe this setting was changed since you created those files?
Files and links:
I have those files from almost the beginning of installing obsidian. This happened suddenly
@ViciousSquid My option there is “Shortest path when possible”
Enable restricted mode and restart obsidian.
Please post a screen recording showing that the files are there but the link does not work
It does not uploading movie document. I have some screenshots
Can you upload here a copy of mapnep and one of the notes linking to it that doesn’t work.
One thing that comes to mind mind is that you may have some weird spaces either in the link or in the filename.
Μεταλλικές Κατασκευές Landmark.md (5.0 KB)
ΦΑΝΟΣ.md (225 Bytes)
“Μεταλλικές Κατασκευές Landmark.md” has the link that directs to “ΦΑΝΟΣ” and the link is not working
In the above map you can see that also not working: “ΧΡΥΣΑΝΘΟΣ”, “ΝΕΟΚΛΕΟΥΣ ΔΗΜΙΟΥΡΓΙΕΣ” and "THE LANDMARK ΤΕΧΝΙΚΕΣ ΠΡΟΔΙΑΓΡΑΦΕΣ¨
Thanks, there is certainly a problem. Will look into it.
I can reproduce with any link ending with a sigma.
And yet a file that is only called Σ does link … :thinking:
I checked my links and it seems that you are right. Very clever!
“Σ” check for “ς” as well
It seams that only words ending with “Σ” is the problem. “ς” is not a problem. It creates the link but the note refering to the link. Afterwords the link is not working. When I press the link it creates the same note but with a number “1” at the end of the title.
will be fixed v1.8
