Linking to header with spacing not working
Minimal example:
Header
Header With Spacing
Header
Header With Spacing
No
A working link for each header.
The link for “Header” works as intended, but the link to the header which includes spacing does not work.
Obsidian Version 1.8.9 for Windows 10.
No additional plugins installed
The format should be:
[Header](#Header)
[Header With Spacing](#Header%20With%20Spacing)
## Header
## Header With Spacing
CleanShot 2025-03-12 at 19.44.18
If you disable Settings > Files and links > use [[Wikilinks]], and use [[ when creating the link, the auto-suggester will create the properly formatted link for you.
CleanShot 2025-03-12 at 19.45.14
