Hello,
I’m a fairly new obsidian user here, but I believe the light mode in Obsidian on macos is not functioning correctly, it looks very dark, except when it is in a menu. I’ve attached a couple of images for reference here.
Changing to a custom css did not fix the issue.
This is using the default light mode
And this is in a menu, where it appears to be functioning correctly
You must have translucency enabled with a dark wallpaper/window behind Obsidian, or something similar is going on. Check Preferences → Plugin → Translucency.
That was it! Thank you very much for your help.
