Level Hierarchy: Is it ok to use multiple H1 headings in a note
I am saving AI conversations for future reference. Their headings generally start with h2 (##). I would like to start each response (next question) in a conversation with a heading to separate it in the outline.
If the conversations start with h2, logically I would separate them with h1. However, coming from web development, multiple h1 headings are frowned upon. I could use a regex to demote all headings in the conversation one level. Or is it ok to use multiple h1 headings in note-taking land? Would this affect the hierarchy tree if it is published on the web?
Multiple H1s are fine inside Obsidian. The one-H1 rule comes from web development, but a note is not a web page: Obsidian’s own help (“Basic formatting syntax”) describes headings simply as six levels you can use as you like, and the core Outline plugin just lists every heading at its level - so several H1s show up as separate top-level entries, which is exactly what you want for separating conversations. One thing to know: with “Show inline title” enabled in the editor settings, the file name already displays as a title above the note, which is why many people start body headings at H2 - but that is style, not a rule. If you publish the note on the web later, the web convention applies to the rendered page again; inside Obsidian nothing breaks. So no regex needed unless you prefer the demotion visually.
My suggestion is not to rely solely on heading levels to distinguish multi-turn AI conversations. Using quote blocks is more noticeable and semantically meaningful, and even if an AI response has an H1, it won’t disrupt the heading hierarchy.
