Searched web - forums
I paste some URLs in to a note and the first letter after the \ is grayed out - how can I stop this effect and not gray out the letters ? Thanks
In Markdown, the backslash (\
) is used to mark when you want to use characters literally (for example, to use an asterisk without marking the following text as emphasized), so Obsidian’s Markdown highlighter is highlighting it.
I think the best solution would be for Obsidian to not do that. In the meantime I think it’s possible to customize how Obsidian highlight Markdown, but I don’t know anything about it.
Put the text between backticks
@Sentiment’s answer marks the text as code (as you may know), which is a pretty sensible thing to do with a pathname like that.
