Left side panel can't collapse in Ipad
Left side panel can’t collapse in Ipad. The button is there but when I clicked it nothing happen
The button can collapse and expand left side panel
Obsidian version: 1.12.4 (299)
API version: 1.12.4
Operating system: iOS 26.3.1 (Apple iPad8,1)
Catalyst license: none
Community theme: Blue Topaz 2026011402
Snippets enabled: 2
Plugins installed: 32
Plugins enabled: 18
1: Dataview v0.5.68
2: Excalidraw v2.20.4
3: Style Settings v1.0.9
4: Advanced Canvas v5.6.6
5: Auto Note Mover v1.2.0
6: Better Word Count v0.10.1
7: Calendar v1.5.10
8: Codeblock Customizer v1.3.1
9: Emoji Toolbar v1.0.0
10: Maps v0.1.5
11: Note Definitions v0.28.4
12: Quick Switcher++ v5.3.0
13: Slash snippets v1.0.16
14: TaskNotes v3.25.6
15: Table Generator v1.4.1
16: Templater v2.16.2
17: Heading Level Indent v2.1.1
18: Omnisearch v1.28.0
Just to be sure :innocent: : Did you test this with Restricted mode enabled, disabled all CSS snippets and using the default theme ?
I’m asking because I do not have a “collapse/expand” icon for the sidebar on the default theme, when the left sidebar is open on my iPad :woman_shrugging: (I either swipe or tap in a note to collapse/close it generally)
I accidentally just did this…..the little pushpin icon next to your vault name on the bottom left. Give that a push.
I’ll move this to Help.
If you’re still having an issue, please follow the steps in the template, especially the ones Pch mentioned above.
