Hi,
I’ve developed a plugin that allows writing on PDFs in Obsidian. Since updating to version 1.8.3 (and later), I noticed that left clicks are no longer detected inside PDFs. Previously (up to version 1.7.7), I could detect left clicks, but now only right clicks are registered.
Expected Behavior:
- Left-click events should be detected inside PDFs (as they were before).
Current Behavior:
- Right-click works (the cursor moves to the clicked position).
- Left-click does nothing and does not trigger any events.
Steps Taken to Debug:
- Disabled all third-party plugins.
- Tested in Safe Mode.
- Checked for
mousedown
events: only right-click is detected. - Rolled back to version 1.7.7 → The issue disappears.
Since my plugin relies on detecting left-clicks for user interaction, this issue is causing problems. Is this an intentional change or a bug introduced in the latest update?
Thanks in advance for your help!
