Any new document typing latex will not show in preview.
latex to appear
latex doesn’t appear
  • Mac Catalina
  • 0.7.3
cmd-shift-i what does the console say?
Here it is attached:
Can you try to complitely delete obisidian and reinstall it?
DId you install obsidian from our installer or some other way?
Hi, I installed obsidian regularly.
I tried uninstalling it from applications before but it seems that obsidian retained all settings. How do I completely delete obsidian?
You’ll want to look in two places:
  1. make sure you remove the .obsidian folder from your vault
  2. the system data is stored in /Users/yourusername/Library/Application Support/obsidian, you’ll want to remove that obsidian directory.
Ah great that solved the problem!
Any idea what lead to this issue in the first place? I’ve seen another report but I still can’t figure our what caused it so I can repro and fix.
