Add latex newcommand declaration:
$\newcommand{\br}[1]{\{{#1}\}}$
Use the command:
$\br{test}$
Close and reopen obsidian. You will whitness that the custom command is not recognise, until you play with the declaration, delete and re-add it again
Obsidian version: v1.9.14
Installer version: v1.6.7
Operating system: Darwin Kernel Version 25.1.0: Fri Sep 19 19:12:09 PDT 2025; root:xnu-12377.40.77.505.1~4/RELEASE_ARM64_T6020 25.1.0
Plugins installed: 2
Plugins enabled: 2
1: Custom Frames v2.5.0
2: Better Export PDF v1.11.0
